Need Fuel Suggestions!
I ham building a 342 stroker(347 stroker rotating assembly with stock bore). I need to know what fuel setup to Run! Its going to be carbureted this is the run down:
Victor JR manifold, GT heads fully ported larger valves, 10.5 CRm BIG Cam ( 282 comp cams performer) 565 intake, 575 ex. BBK long tubes, Underdrive pulleys. NO AC OR P/S, Moros 7qt Pan, Borg Warner T5, Ram Clutch & Flywheel, aLuminum Drive shaft, 8.8 with 4.10 gears 31 spline. MSD all over! I need Fuel pump and CArburetor suggestions, and fuel line size!
[IMG]local://upfiles/49087/9E39910D1463427FA997B68940D246C4.jpg[/IMG]
RE: Need Fuel Suggestions!
ORIGINAL: 342strokermotor
Are those gt 40 heads you have? If they are stock heads they are really going to hurt you setup. You should be fine with a holley blue pump and I would run new 1/2 fuel line or 8an line. A 650 speed demon or might demon with mechanical secondaries will probably be one of the best carbs to go with. Are you going to use a sumped setup or a pickup in the stock tank? Right now I'm using a granetelli pickup in the stock tank and it works fine.
Yea I know the heads are goign to hurt me bad, I am waiting to save up, I used them cause they were practically free, just hadda get dem re surfaced, valves clean, etc. etc. I will step up to AFR 185 cc HEADS SAP!!!!!
I think either Holley black pump or Aeromotive S/S pump. Put filter between tank and pump. In fact I would sump the stock tank.
1/2 hardline up to the engine bay then -8 to the regulator then -6 to each side of carb.
I would use a 750 Holley or Barry Grant. If the car is for street use with an auto trans and not much gear/convertor I'd do a vacumn secondary...
