still boggin bad... no power
RE: still boggin bad... no power
not the ignition coil.... replaced that,... buddy of mine said bad mass air flow sensor??? the hottere the motor gets the worse it bogs down... put 500 in it already... nothing is fixing it.. going crazy slowly but surely...HELP!!!!
they are fine, just replaced them too, previous ones were a little coated.. not bad though... i just keep thinkin its my timing... but it runs so damn good at idle.. its when there is a load is the problem, it gets up fine to 2500, 2800 rpms, then it just bogs and sounds like hell, then it shifts rough because the tranny is tryin to shift with the motor... i took it to a shop, they told me tps or mass air flow, i did the tps this mornign, no change... any suggestions on a mass air flow for a stock app????
yo dude trust me on this! i had the same problems! i spent 500 bucks on it 2 and nuttin was found, i cleaned my MAF sensor and changed my o2 sensors and BAM car runs better then ever!! so clean your MAF!!!
You will need a MAF computer, a MAF sensor, and the wiring harness. You can buy all of this new and pay about $580 or you can go to a junkyard and rob them off of a MAF mustang up till 1993. After that is a whole different setup. This will cost you atleast half of that.
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
