cylinder head question
ok i found a place where i can get a set of cast iron heads, both for $600, fully assembled. 2.02 intake, 1.60 exhaust; but my question is, will i have to notch the pistons?
RE: cylinder head question
ORIGINAL: Ecstasy
ORIGINAL: hot85fifty
no it wil not work...the only heads with 2.02 that will work are the twisted wedge heads... otherwise you will have to notch the pistons... every company that i asked always said that..
the b-303 cam is bigger than the e-303
You can't just say it will or won't work....are you using stock pistons? You may be okay, but I would absolutely clay it up to verify PTV clearance.
