Stock HP From a 93 5.0L Stang?
RE: Stock HP From a 93 5.0L Stang?
ORIGINAL: Wirth_GT
From 1987-1992 the horse power was 225hp and 300 ftlb of torque 1993 was 205 and 275
ORIGINAL: silver91gt
what about the 93 cobra?
Edit --- This was taken from another post, here is EXACTLY what the cobras came with
Cast iron GT40 heads
Cast aluminum Cobra intake manifold
Crane 1.7 rocker arms
24lb fuel injectors
Cobra specific ECU (computer)
"Cobra" stamped valve covers with build sticker and signature
Engine oil cooler
Front mounted power steering fluid cooler
Lightened flywheel
Phosphate coated transmission gears
Overdriven waterpump pulley
Cobra specific camshaft
Cam specs: Duration: 227°/Intake & 270°/Exhaust
Lift: .485/.485 Intake/Exhaust
Lobe separation: 118.5°
This is just a little extra stuff specific to the 5.0 Cobra as well. The interior and exterior differences arent listed because I figured they were obviouse enough.
Suspension/Brakes
13" Front brakes
11.65" rear brakes
"Cobra" embossed front calipers
Cobra specific brake booster
Cobra specific rear sway bar
Cobra specific shocks/struts/springs
K-member that is slightly stiffer than the GT's
No strut tower brace
Thank 94Cbra for this post.
dalefrancis88
09-11-2015 07:15 AM
09-10-2015 08:39 PM
kawiguy827
09-01-2015 07:09 PM
