Best sound out of exhaust
Old 07-24-2004, 01:31 AM
jma91678
jma91678's Avatar
Default Best sound out of exhaust
I have a 91 gt with shorty headers hpipe and flowmasters. I am needing to replace the muffler back and was wondering witch series of flowmaster is the loudest. and would 3 in tailpipes sound better. have 2.5 now. Also i heard that it sounds better if i close off thecross pipe on the h pipe for a true dual set up? Thanks for any advise
jma91678 is offline
Old 07-24-2004, 02:32 AM
luckythirteen13
luckythirteen13's Avatar
Default RE: Best sound out of exhaust
i wouldnt plug up the cross section. it there for a reason. as far as mufflers, id go with magnaflow if you want it loud.
luckythirteen13 is offline
Old 07-24-2004, 03:10 AM
bobby
bobby's Avatar
ya def. dont plug the h. if u want loud i got 3 words for u. ONE CHAMBER FLOWMASTERS!!!!!!!!!
bobby is offline
Old 07-24-2004, 03:48 AM
89muskratGT
89muskratGT's Avatar
the connection in the H pipe is to keep the the pressure equal so like they said dont plug it up and if you want loud exaust dont put tail pipes on the mufflers
89muskratGT is offline
Old 07-24-2004, 03:52 AM
bobby
bobby's Avatar
ya go with dumps, my exhaust setup is listed below with 2 chamber flows and it sounds gggggggreaat!!!!!!!!!!!!!!!! hey muskrat, i like that name, my granpa always calls mustangs muskrats
bobby is offline
Old 07-24-2004, 06:54 AM
FoxGT
FoxGT's Avatar
The connection in the H is for vacuum. You may have heard the saying that some cars these days need backpressure. They don't NEED it, but it does eliminate a little restriction. The exhaust primaries coming into one pipe create a vacuum so it will help pull the exhaust out of the cylinders. A four cylinder car with an exhaust pipe for each cylinder would be slower than one with one main exhaust.
FoxGT is offline
Old 07-24-2004, 01:34 PM
crkitup2002
crkitup2002's Avatar
Back pressure is needed yet depending what has been done to your car. You will lose low end power in your stang if the motor is basically stock however gain top end power from a large diameter exhaust. The h-p is there to equalize back pressure and cylinder bank exhaust valve gases with unequal pressures. Don't plug it, you will lose power, plus the sound from your exhaust will be unequal. I'm running a 91 GT with a T5 conversion, Exhaust= BBK h pipe, with magnaflow catback, very louddd and sounds great behind a 5 speed.
crkitup2002 is offline
Old 07-25-2004, 03:48 PM
Killa89and66Verts
Killa89and66Verts's Avatar
Unless your car has alot of HP changing from 2.5 to 3 in will also hurt ur performance...it might look cool but it will hurt the overall performance of ur engine...also dont plug the h pipe
Killa89and66Verts is offline
Old 07-26-2004, 11:02 AM
91GT50
91GT50's Avatar
I have flowmasters "American Thunder" and when you punch it let me tell the whole neighbourhood knows it !!!
[sm=smiley20.gif]
91GT50 is offline
wawagner82
09-13-2015 09:02 AM
09-10-2015 08:39 PM
Emblazoned
09-03-2015 10:45 PM
kawiguy827
09-01-2015 07:09 PM
Quick Reply: Best sound out of exhaust
