Battery relocation...
Old Oct 11, 2006 | 12:30 AM
  #31
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Battery relocation...
ORIGINAL: PONY GUY
then a spool would deffinitly fix you twisting problem by putting equal tourqe on both tires
Oh I'm not having that problem. I was just speaking hypothetical.
Old Oct 11, 2006 | 01:12 AM
  #32
sc94gt's Avatar
sc94gt
Does moving the battery to the trunk make it harder to start on colder days especially?
I would think unless you have a thick enough cable it would lose some power with all of the extra feet to travel.
Old Oct 11, 2006 | 01:14 AM
  #33
PRO50SC's Avatar
PRO50SC
The Rogue Mod
No, the cable I have is either 2 or 1 gauge. It's big!! Never been a problem. Oh you can see it, It's 2 gauge
Old Oct 11, 2006 | 02:18 AM
  #34
brando5.0's Avatar
brando5.0
Pro50- If you think about the way the driveshaft and rear end spins, the natural tendency is for the right rear to spin- the way the driveshaft spins in the rearend and through the carrier it just torques the entire back end. The opposite is true for the front. The same theory applies, and makes it pull the front left. The entire car twists to make the front left pull. You'll see that on a lot of high horsepower cars. BTW: Pulling the front swaybar will make the left front lift more, and take weight off of the front end.
As far as the battery in the trunk...you'd have to check with your local track. Most require an NHRA approved ( I know Moroso makes one) battery box that vents outside the car. Also, a "push to kill" or "turn to kill" ****/switch is required out the back somewhere. A couple suggestions from my local track is under the license plate (remove the plate to race) or to drill a small hole through the tail light and run a rod through to the kill switch. I agree though- though loosing a few front end pounds with the battery in the trunk vs. a drycell, it does make the engine bay a lot cleaner, and gives room for an aftermarket ignition, or other goodies.
Old Oct 11, 2006 | 02:20 AM
  #35
primetime5.0's Avatar
primetime5.0
thought it need to be full box to pass tech?
Old Oct 11, 2006 | 03:01 PM
  #36
2 kwik's Avatar
2 kwik
I ♥ Acer
I have to laugh at most of you with all this crazy talk about a battery relocation I just pull out my NAPA battery and put in my drycell wieghting at a whoping 9 pounds,bought the same as the wieght you guys add with all the wiring and box
Old Oct 11, 2006 | 03:02 PM
  #37
2 kwik's Avatar
2 kwik
I ♥ Acer
[IMG]local://upfiles/34864/59289FB531344691AF985872A318468E.jpg[/IMG]
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
logan409
Sep 26, 2015 07:43 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
Art161
Sep 9, 2015 10:33 AM
