Ok I have $8k to spend help me spend it
#21
RE: Ok I have $8k to spend help me spend it
onetrickpony Date 10/24/2006 12:35:03 AM
quote:
ORIGINAL: I3atR!ce
i'm thinkin if i had 8 grand to spend i would start with a 331 stroker kit, some afr heads, custom cam, rpm intake and a novi 2000. that with the supporting mods (tb, egr, exhaust, injectors, maf, ect.) and suspension and i would be totally happy. that with some pizza and beer, and me and my buddies would have a real good time with the install.
umm, Isn't that kind of what I said?
quote:
ORIGINAL: I3atR!ce
#22
If it was me I would just throw a supercharger on it. Save the rest and save more, then when the stock motor goes belly up buy or build or own custom blower motor. At least you will already have the blower for it.
#23
ORIGINAL: Creetan
Thanks alot for the ideas. Does anyone know what I should do to my chassis/suspension. I don't have the proper tools to fab alot of stuff up so the best mods with least fab work would be great. Hell bolt on and go would be even better. I am still open to all ideas for anything. I am even open to ideas that have nothing to do with engine or chassis/suspension but would help overall performance. Thanks again
springs
shocks/struts
U/L rear control arms --don't go cheap if you'll be at the track that much.
Panhard bar -- MM has a great one.
I don't know enough about drag suspension setups to give advice, so I'll leave that to someone else. Don't go cheap on your control arms b/c you'll end up spending the cash later when you break something.
Also, lose as much weight as you can. Aluminum heads will drop 55#'s off the motor. Tubular K-member and A-arms will drop another 30#'s. Lose the smog, A/C, and power steering if it will be mostly a track car, otherwise that's up to you. There's more, just do a search to find some past threads.
#24
Yes, MM's panhard is supposed to be the best. But watch out, install is not easy! I have been trying to just UNDERSTAND the directions for the past three days!
#26
ORIGINAL: aode06
id sell that one $2800+
, and buy one already modded to save a few grand.
just a thought.
just a thought.
#28
DSS 331 Stroker Small Block W/ Forged Relieved Pistons and Girdle $2000
Trick Flow Street Heat Top End Kit $2200
Tremec TKO 500 Tranny $1800
Misc. Suspension/Supporting Mods $1500
Brake Upgrade SSBrakes A112-2 Kit $1600 (you can do this cheaper but this kit is the pull off and bolt on all new way)
Hellion Turbo Kit $5000
New Drivers Seat for when you **** yourself the first ten times you drive it $200
Total Build:$9,100 w/o turbo, $14,100 w/ turbo... this is just a dream list, you could build a faster car for less... LOL
#29
R302 block...
forged stroker kit...
185 AFR heads...
custom grind cam...
shift kit...
built C-4 tranny...
Transbrake...
Upper/Lower control...
torque boxes...
tubular K member...
coilover front and rear...
no A/C...
no smog pump...
locker...
gears...
axles...
disc brake conversion...
body and paint...
If you would like to go with a stick shift, you could go with a G-force tranny with a solid clutch...
Drag Radials...
Your choice of wheels...
Pick and choose as you please, I think this will get you ready for a twin turbo set up. Good Luck.
185 AFR heads...
custom grind cam...
shift kit...
built C-4 tranny...
Transbrake...
torque boxes...
tubular K member...
no A/C...
no smog pump...
locker...
gears...
axles...
body and paint...
Drag Radials...
Luke9222
10-22-2015 11:55 PM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
