What backspacing and whatever do I need to run 275's?
I've removed the quad shocks and am looking at buying a set of wheels/tires.
They have these 4 sizes available.
15x8
15x10
17x8
17x9
I either want to run a 275/50/15 or a 275/40/17, what do you guys think?
Also, my car is now 5lug/rear disc, from a 94 GT. I currently have 94 GT 17x8 wheels on, but I'm not sure of the bolt pattern and offset needed? Or backspacing, whatever its called.
This is going to be a track car/weekend driver, so should I bother w/ 10" wheels out back? I don't think I can fit any wider than 275's out back, and 245's up front, am I correct?
Thanks guys.
15x8
15x10
17x8
17x9
Thanks guys.
RE: What backspacing and whatever do I need to run 275's?
Using 94 spindles? Seems like they are a little longer than fox axles. If that's the case, 15x8 on 5.5" bs would work good. Might have to roll the fender lip and do some massaging to the inner fender though.
ORIGINAL: 4fit?
15x10 youll need a 6.5 inch bacspacing!! 15s are the way to go! you will def have to beat the inner fenderand roll your quarters! good luck they will be fine! idrive every day with my draglites 15x10 in the back 15x5 in the front easier than 15x3!
ORIGINAL: BAM614
I kinda like how my 245/45/17's look like now, with the tire size. So is there any advantage to going with 15's over 17's?
ORIGINAL: 4fit?
More sidewall.
ORIGINAL: BAM614
Which gives me....? Better traction? Better ride? etc? Care to explain why more sidewall is better?
And if I can get 275's on an 8" wide wheel, why would I go to the 10" wide ones? Just curious...
ORIGINAL: BAM614
09-01-2015 08:16 PM
