not starting
RE: not starting
codes, codes, codes, theres a code for neutral safety switch/ clutch engaged that'll trip if the clutch isn't fully depressed when starting car...i think it 67....not positive though
RE: not starting
i have a push button start ignition switch... but my car will not start, if i push it it starts. could it be my battery. the door chime is really low too, is that supposed to be loud? what could be my other problems
RE: not starting
put it in neutral and push pedal to floor. That rules out the cable. If it clickes loud in the starter, its locked up. If it continuously clicks, then it could be dead battery or cylanoid or loose terminal connections. if it doesnt even crank or click and the lights go dim when you try to start it, its the battery. have you tried to bump start it?
RE: not starting
ORIGINAL: burn rubber
when i push my switch for the solenoid it ticks like its trying to turn over but battery is reading just above the 8
dalefrancis88
09-11-2015 07:15 AM
