351 Clevland or Windsor??
Old Nov 6, 2006 | 08:53 PM
Chuy1988's Avatar
Chuy1988
Default 351 Clevland or Windsor??
I have a few questions on a 351.
What is the difference between the 351C & 351W?
Which one is better?
Will both fit the stock 5 speed tranny?
Which would you go with??
Which is better FI'd (Fuel Injected)?
Thanks!
Old Nov 6, 2006 | 09:13 PM
Black Snake's Avatar
Black Snake
Default RE: 351 Clevland or Windsor??
Clevland is considered a big block and winsor is small block.
Heads are differnt and valley pans.
The winsor takes less modifications to work.
nmerrill's Avatar
nmerrill
I dont know the exact differences between the two but i think you'd be much happier with a windsor. They are much easier to make power, and will bolt up farily easy. The windsor will fit the stock 5 speed whereas the cleveland will not. I dont think i have ever even seen a fuel injected cleveland either. Windsor FTW!!!!
Old Nov 6, 2006 | 09:15 PM
PONY GUY's Avatar
PONY GUY
NO a Cleavland was never fuel injected .Windsors make more Hp and hold up better to High Hp that a 302
Old Nov 6, 2006 | 09:29 PM
Chuy1988's Avatar
Chuy1988
Thanks for your reply's.
Old Nov 6, 2006 | 09:35 PM
chath_brick's Avatar
chath_brick
most of your 5.0 parts will bolt up to the windsor, since they're both windsor blocks. a cleveland is totally different, so it would be much harder to make work in a mustang.
Old Nov 6, 2006 | 09:54 PM
hellas85stang's Avatar
hellas85stang
lmao a clevland blows the doors off a windsor..yall need to check info and read.. a clev has huge valves and huge ports and flow tons of air up top..and the block is taller then a windsor.. ask a real exp engine builder that knows like a machine shop..ill take a clev over a windsor any day..butthen again i know the difference in them...clevs are a lil more $ to have done as far as intakes and stuff,but are awsome power plants..all ya have to do is read a book,and learn..somtimes gettin info on here isnt allways right...donttaker my word for it..check the facts...
Old Nov 6, 2006 | 09:56 PM
mattdel's Avatar
mattdel
hellas is right clevelands will eatup windsors all day, but its almost impossible to find good cleveland parts, let alone performance parts.
Old Nov 6, 2006 | 09:58 PM
PONY GUY's Avatar
PONY GUY
ORIGINAL: mattdel
got that right and if you do find them Its $$$$$$$$$ to get them
Old Nov 6, 2006 | 10:38 PM
ih8chevy's Avatar
ih8chevy
first of all the cleveland is not a big block, second of all the parts for a cleveland are very hard to come by third off it wont bolt up to ur tranny u will need a C4 or a toploader, the windsor is better for two reasons, bolts right up to the fox platform and aftermarket scene is huge. The cleveland is a much better motor stock, it has well over 300 hp and has sent 1971 mustangs down the 1/4 mile in the mid 13's stock. But as far as puttin one in ur fox stick wit a windsor
