? about switching to carb
Old 11-16-2006, 01:12 PM
warthrone
warthrone's Avatar
Default ? about switching to carb
Please help out if possible... I have an 88 speed density that Im rebuilding the motor on, but before I spend over 1,100$ on mass air conversion, new intake, injectors, throttle body etc.. I have a question about carbing this setup instead.
What exactly do you have to do to switch to carb computer-wise? I mean does the alternator or anything other than ignition and distributor have anything to do with the computer? What else do I need to do so there's no strange problems going on.
Thanks!
warthrone is offline
Old 11-16-2006, 01:20 PM
88BlueGT
88BlueGT's Avatar
Default RE: ? about switching to carb
You need a carb, a new reg, manifold and Im not sure abou the dizzy. Double check on that.
88BlueGT is offline
ZachW04Stang
ZachW04Stang's Avatar
You need a new distributer and fuel pump. I had a powermaster alternator with 1 wire setup so I didn't need to rewire the factory one. I'm not sure if you really even have to it might be on a different harness. You can remove the computer and the powertrain harness. They won't be needed after a carb swap.
ZachW04Stang is offline
Old 11-16-2006, 01:43 PM
GaryBisiniere
GaryBisiniere's Avatar
you do not need a new fuel pump you just need to re wire it.
GaryBisiniere is offline
Old 11-16-2006, 01:53 PM
warthrone
warthrone's Avatar
but is the in tank (opposed to like a holley blue pump) fuel pump too high pressure for the carb?
Old 11-16-2006, 10:43 PM
tinman
tinman's Avatar
The fuel pumps for EFI are way too high pressure for a carb.
I'd use an Aeromotive or a Holley Blue pump and in any case a regualor with it set to about 6-7#........
tinman is offline
Old 11-16-2006, 11:16 PM
Joel5.0
Joel5.0's Avatar
You want to check http://www.jason.fletcher.net/tech/e...b/efi-carb.htm
Joel5.0 is offline
Old 11-16-2006, 11:21 PM
HACKGT350
HACKGT350's Avatar
you dont need a holley blue the red will do just fine and its rated to pump enough fuel for over 500hp but you will need a new intake manifold the carb best way to do the dizzy is get something like this one which an just be hoocked up to msd ignition box like the 6al http://www.mustangsunlimited.com/ite...s&CatKey=74-01
HACKGT350 is offline
lincolnshibuya
07-05-2020 03:05 AM
PaulH2
20
01-31-2016 09:48 AM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
guitarman376
09-30-2015 05:54 PM
Quick Reply: ? about switching to carb
