Need help with my 5.0
i have a 88 mustang with a 5.0 and lately i did an engine rebuild with some bbk equal length headers, a comp cam, port and polished heads, and a cobra intake. we got it running but for some reason when it heats up it backfires through the intake and it sputters. any ideas to what the problem is would be appriciated. thanks
RE: Need help with my 5.0
ORIGINAL: PRO50SC
Same as any other, w/ a timing light.
ORIGINAL: zajones08
how do you time a car with electronic ignition?
once you are sure that you have installed the distributor correctly, use a timing light to set your timing by rotating the distributor. Also be sure to remove the SPOUT connector (the little gray plug) that is attached to the distributor harness
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
