intermitant starting
Old Nov 18, 2006 | 06:02 PM
rthmotorsports's Avatar
rthmotorsports
Default intermitant starting
hey all, a quick question. Got a 89 GT, starter is good, turning over. I just lose spark. got a new cap, rotor, coil and ignition module. anyone here of this before. Need help, going crazy,
Thanks,
Bill
Old Nov 18, 2006 | 06:06 PM
mattdel's Avatar
mattdel
Default RE: intermitant starting
bad ignition ground to the PCM? if thats the case, good luck tracing it through the dash.
86 5.0L's Avatar
86 5.0L
getting fuel
Old Nov 18, 2006 | 06:35 PM
dimebag's Avatar
dimebag
my guess is you have a loose ground or connection somehwere... might wanna invest in a manual for your car, w. wiring diagrams....
Old Nov 18, 2006 | 08:37 PM
rthmotorsports
where is the PCM located? getting fuel alright. Just no spark. put a tester on it. thanks for the info, if anymore out there, let me know.
Bill
Old Nov 18, 2006 | 08:45 PM
mattdel's Avatar
mattdel
find the ground wire to the ignition module, hook a test light up to the positive terminal on the battery. touch the tester to the ground wire for the module. if the ground is good, the light will go on. should be grounded KOEO and KOER
Old Nov 18, 2006 | 09:03 PM
AdderMk2's Avatar
AdderMk2
Banned
PIP in the distributor
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
dalefrancis88
Sep 11, 2015 07:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
