cam question
RE: cam question
Different companies measure difference from a different starting point. So the same cam could have a different measurement from brand to brand. That's why there is duration @ .050. Every manufacturer starts from the same point so there is a fair comparision.
RE: cam question
Ther are some folk's that say that the duration @.050 don't mean much untill lift is over .600 but I think they are full of it.
There is NO SAE standard that I know of for measuring cam duration.
Use the .050 numbers and I think you'll be OK......
RE: cam question
Ecstasy, wrong-o bud. With a longer stroke you can use both more lift and duration.
Within limits.
Where I think lots of peeps get into trouble is the cam grinders like to ,list everything for a small block Ford togather in the books and then the guy gets too much cam in a 5.0.
Same can be done with heads too, it's easy to get too much.
Heads, induction, compression, bore and stroke all have to be taken into account before any cam selection can be made......
Within limits.
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
