BACK FIRE
Old 12-04-2006, 11:25 AM
ROTTITANK
ROTTITANK's Avatar
Default BACK FIRE
Cant a lower octane fuel cause back firing. I put 93 in and havent back fired yet. If this is the case that ...great problem solved.
ROTTITANK is offline
Old 12-04-2006, 11:35 AM
PONY GUY
PONY GUY's Avatar
Default RE: BACK FIRE
carb or fuel injected????
you might have to play with you timing and if you have a carb play with air fuel ratio too
PONY GUY is offline
Old 12-04-2006, 11:47 AM
ROTTITANK
ROTTITANK's Avatar
Its fuel injected with 24lb injectors ,tfs2 cam and 14 drgress timing.
Old 12-04-2006, 11:50 AM
PONY GUY
PONY GUY's Avatar
I would play with your timing also might have a 02 sensor going I would check for codes and run a self test if you have access to a scan tool
PONY GUY is offline
musnicki
09-23-2015 07:11 AM
spamedic
09-09-2015 12:15 AM
cbird1177711
09-02-2015 04:12 PM
09-01-2015 08:16 PM
Quick Reply: BACK FIRE
