need help!!!!!!!! oil pressure problem
Old Dec 6, 2006 | 05:43 PM
mostdef's Avatar
mostdef
Default need help!!!!!!!! oil pressure problem
i have an 87 t top which i just did a full rebuild with a high volume oil pump.new bearings and rings an f cam and new lifters...with a mass air conversion pig tail....i got it running about a week or two ago and when it started oil pressure was about 57 to 60 psi...just recently it has droped down to about 40 psi...does anyone know what it can be.??? please let me know what u guys think
Old Dec 6, 2006 | 05:54 PM
primetime5.0's Avatar
primetime5.0
Default RE: need help!!!!!!!! oil pressure problem
stock or aftermarket gauge?
Old Dec 6, 2006 | 05:55 PM
92hatchLX's Avatar
92hatchLX
is it at 40 when idling? driving? what rpms?
Old Jan 23, 2007 | 07:39 PM
mostdef's Avatar
mostdef
no at idle it used to be around 50 or 60 but when the engine finally broke in the oil pressure gradually droped at idle...i took the engine out when it would idle aroun 15...and after amrket auto meter gauage
Old Jan 23, 2007 | 07:41 PM
turbosha's Avatar
turbosha
40 at idle aint to bad, does it raise as your rpms come up ? whats the peak oil press?
Old Jan 23, 2007 | 07:42 PM
turbosha's Avatar
turbosha
the rule of thumb is 10psi oil press for every 1000 rpm.
Old Jan 24, 2007 | 06:41 AM
mostdef's Avatar
mostdef
yeah the rpm jumps when i rev it....but at idle it stays around 10 or 12 now....i may have spun a bearing
Old Jan 24, 2007 | 11:13 AM
ahittz24's Avatar
ahittz24
Did you properly break the motor in? Or did you get in it right after the rebuild and raw dog it?
Old Jan 24, 2007 | 11:38 AM
disturbed471985's Avatar
disturbed471985
Did you let the rings set before u blasted it?? Id say maybe a ring as came unseated. Rebuild!
Get comp test done!!!
Old Jan 25, 2007 | 02:10 AM
mostdef's Avatar
mostdef
na i drove the car for about 1000 miles and didnt rev past 3 or 4 the MOST!!!. right when everything was feeling smooth the oiol [pressure started to drop slowly but surely
articman
Jun 21, 2018 11:45 PM
StalkerGT
Sep 25, 2015 02:41 PM
bconboy
Sep 21, 2015 12:52 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
