Help with codes...
Old Dec 6, 2006 | 06:14 PM
dj1203's Avatar
dj1203
Default Help with codes...
hey i was pulling codes and got a code 314 AIR system inoperative during KOER (Bank number 2 with dual heated oxygen sensors). I also pulled code 332 insufficient egr opening detected. are these two related and what does the 314 code mean.
Old Dec 6, 2006 | 07:42 PM
fourfivefour's Avatar
fourfivefour
Default RE: Help with codes...
Check your vacuum lines for leaks and proper routing. Any leaks or misrouted vacuum lines could set both of these codes.
Old Dec 6, 2006 | 07:49 PM
dj1203's Avatar
dj1203
thanks for your reply, i will check the vac lines, i only know a little about there proper placement, anyone know of where a good diagram might be, i have a haynes manual but i don't see such a diagram.
Old Dec 7, 2006 | 10:06 AM
fourfivefour
There should be a vacuume diagram under your some where. Unless it was removed.
colschw
Aug 16, 2014 09:12 PM
antnvlz1294
Jan 5, 2014 11:53 PM
jawknee5
Oct 27, 2012 01:35 PM
Bowtietraitor
Dec 16, 2010 08:56 PM
Fifthwind
Oct 26, 2010 07:42 PM
