AFR heads and Speed-Pro pistons??????
Old Dec 8, 2006 | 01:43 AM
Stangnsnow2's Avatar
Stangnsnow2
Default AFR heads and Speed-Pro pistons??????
hey guys i have a 302 bored .020 and i have these pistons in there:
TRW-L2488F Speed-Pro
Deck height: 8.206 in. Deck clearance: 0.003 in. Skirt clearance: 0.0018 in. Weight: 597g. Approximate compression ratios: 10.51:1 with 54.5cc, 9.99:1 with 58.2cc, 9.72:1 with 60.4cc, 9.41:1 with 63cc
I want to get AFR heads and these are the ones im thinking about getting, but i hear that the pistons need to be notched???? does anyone know if my pistons have to be notched?
AFR# 1388 - 185cc Street/Strip Heads, Stud, 58cc (NON-Emissions) OR
AFR# 1387 - 185cc Street/Strip Heads, Stud, 61cc (NON-Emissions)
2.020 intake valves, 1.600” exhaust valves, combustion chamber volumes of 58cc or 61cc, and 69cc exhaust ports, AFR’s new 185cc Ford head is designed for 302-351 cid engines operating from 1500 rpm to 6500 rpm. A 3/4” thick head deck makes the AFR head ideal for nitrous or blower applications. Will not accept rail rocker arms. Hardened pushrods required with heads #1420 and #1422. High flow 2.020 valves might require aftermarket pistons notched for valve clearance.
Note: Late-Model Ford 302 engines must have stock pistons notched for clearance.
Old Dec 8, 2006 | 01:46 AM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: AFR heads and Speed-Pro pistons??????
We have a 302 at our shop right now with the same pistons but .030 over and it has world heads w/ 2.02 valves and b303 cam and the intake valves tap the pistons.
Old Dec 8, 2006 | 02:03 AM
ih8chevy's Avatar
ih8chevy
yea you will have to notch the pistons i called afr and emailed them and they said that on 302 pistons u have to notch them, i think u have to do it for the after market ones too
email afr they will definetly kno
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Drastang
Sep 30, 2015 03:48 AM
