5 Lug disk brake conversion
I know this probably came around more than once but Im considering doing the swap and just need to know if I need to use 94 and up spindles or can I stick with what I got and just repalce the rotors oh yeah its a 89 Im going to a junk yard and taking everything off a new body and will I need any extra lines or fittings or brackets for the back and will I be able to pull everything I need of the new body thank you
RE: 5 Lug disk brake conversion
You can use rotors from an 80s Lincoln, a Mark VII i think it is. Or should you go with the SN-95 parts get the spindles, hub, and the rotor. Dont forget the banjo bolts as youll need them. Theres something about using spacers (a couple washers wil work) but i dont remember for exactly what right now.
Google is your friend...
5 Lug conversion
BTW, I would switch over to the Steeda X2 Ball joint... (Insted of that spacer stuff.) Lowers the front end 1/2" and helps with the front suspension geometry...
5 Lug conversion
Woops, saw that he mentioned spindles... I am at work and don't have the link. In a nut shell: Grab everything from the rear brakes; calipers, bolts, etc. AND axles, this will push out your rear 3/4" on each side... When I get home I will post a link...
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
