spout connector
spout connector
I was adjusting my timing and removed the spout connector, got it timed good and when i put the spout connector back in it starts choking during acceleration. Runs good without the spout connector. Any ideas what it could be? I put the spout connector in while it was running. Could that screw things up? Its on a 87 5.0.
thanks,
Ben
thanks,
Ben
RE: spout connector
Perhaps you set the timing wrong. What did you adjust it too? It won't screw anything up by connecting it KOER. The only thing SPOUT is for is to allow the PCM to further advance the timing from the base setting. So, if you allow the PCM to do this and it runs poorly - likely timing is too advanced (should ping and be difficult to start). You run off your base setting with SPOUT disconnected.
jwog666
12-27-2021 08:09 PM
Seanam
10-04-2015 10:15 AM
TfcCDR
09-14-2015 12:08 PM
