NEED HELP ASAP
NEED HELP ASAP
ok guys heres the issue. i have a 302 swapped over to carb,with a b303 cam and a points dist from a 72. motor started off as a 93 outa a town car?
i was told to set firing order 137-----, but when i do it does not run atol not even a pop. i put it to the 15------ order and it ran like crap for 5seconds and died. i need help code enforcement is on me for it.
when i put cam in the timing marks on gears face each other right? my buddy aske dme if it was tdc and marks linded up but cant rember if it was. if marks lined up do i still have to check tdc?
need some insight quick.
THANKS
THANKS
