Is this normal??
Old Dec 28, 2006 | 12:42 AM
GeraldineRyder's Avatar
GeraldineRyder
Default Is this normal??
today on my way home from work i lost all my brakes, no pedel, or e brake, will i get home and realize that fluid was leaking out of my caliper, found out it eas a loose bleeder screw, well i tightened it up, and filled up my master cylinder with brake fluid and while i was bleeding my brakes all the "old" stuff that came out was green. Is that normal??
Old Dec 28, 2006 | 12:48 AM
PJB's Avatar
PJB
Default RE: Is this normal??
Ive never seen green brake fluid.
The e brake is mechanical and must be broken because it should definately work even if the hydraulic brakes dont. Check for loose/broken cables and check if theres any material left on the rear shoes and check the adjustment of the rear brakes because something is definately wrong with the e brake.
Old Dec 28, 2006 | 12:50 AM
GeraldineRyder
found out that the spring that goes on the e brake cable is gone, but i still wanna know wha is the green ****
LTnone's Avatar
LTnone
What's the stuff smell like? Sweet/fishy? You didn't fill the brakes with coolant, did you?
Old Dec 28, 2006 | 12:55 AM
GeraldineRyder
Hell no, i didnt fill the brakes with coolant, ive been building cars for a while and i havent herd of anyone beeing stupid enough to do that.
AdderMk2's Avatar
AdderMk2
Banned
I would say its time for you to do a full scale brake fluid flush.... I'm gonna be flushing mine out this winter along with new pads and rotors all the way around
Old Dec 28, 2006 | 02:40 AM
SSKiller's Avatar
SSKiller
I have seen it before.........In a couple of race bikes. The fluid boils under heavy braking and extended useand changes color.
FivePointToTheOh
Mar 9, 2020 10:26 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
guitarman376
Sep 30, 2015 05:54 PM
96stang3.8
Sep 10, 2015 06:42 AM
