smog pump removal
#22
RE: smog pump removal
ORIGINAL: xc_ute
Pleae read this before doing ANYTHING!
Some of the replies are quite amusing, "...buy a shorter belt".
Hello, 5.0's don't have "V" belts, they have serpentine belts which come in two lengths: one for engines with A/C and one without. There is no serpintine belt for cars without power steering either.
Once I get a new March alternator bracket and straight line tensioner, I can lose the stock tensioner and A/C bracket all together for an even cleaner front end of the engine look!
#23
[sm=icon_rofl.gif] only one length serpentine belt and so what do all the other auto makers use? everyone uses the same length and width belt heck that would be perfect.are you sure you dont live in Kansas and let me guess your name is Dorthy now welcome to the REAL WORLD.
#24
Um, yah, last time I checked, the belt I buy doesn't say "Ford Mustang serpentine belt" on it. Hm, wonder why, oh, that's right, it's not made specifically for the Mustang!
Yah, my car takes a very weird length serpentine belt, it's the standard 6-rib of the Mustangs of my time, but it's length is "888" whatever that is, don't know if that is inches, centimeters, or what. But the item code would be 060888.
Anyway, my point is, the belt is labeled by number of ribs, then length of belt, which would SUGGEST that they would have more than TWO sizes, lol.
#25
ORIGINAL: uedlose
#26
Yep, there are only two serpintine belts for the Mustang 5.0. Don't beleive me then go down and ask that guy making the big $$$ (at least $8) behind the counter at your local "Auto Parts R Us. You and I know there are various lengths belts but "Bubba" isn't geting paid to know or sell you something the computer doesn't say applies to a Mustang. You and I don't work there because we are overqualified.
As for why running a shorter belt isn't such a great idea:
Ford engineeres follow STANDARD drive belt pratice by routing the belt up from the air pump and AROUND the water pump. The routing you suggest, running the belt from the alternator directly to the water pump results in less SURFACE AREA CONTACT between the SMOOTH side of the serpintine belt and the SMOOTH surface of the water pump pulley.
The energy that drives the water pump comes from the friction between the smooth belt surface and the smooth surface of the pulley.
Next you are going to say the resistance of the water to the water pump blade's movement isn't enough to cause slippage when the belt has decreased surface area contact...
Learn the hard way!
Learn the hard way!
#27
I don't need to learn the hard way, have seen and talked to several guys who have it set up this way and they drive theirs on the street and have no problems whatsover with it. I know on my drag car it will be just fine.
FYI, I've probably sized more belt drives for industrial equipment than you have years of age, so you don't need to be such a wise *** about it, unless you can explain what the belt length arc correction factor is for!
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
