speedo issue
RE: speedo issue
The 6 15mm bolts you are talking about are only half of it. Notice the shifter on top of the tailshaft. that needs to be taken loose also. There is a rod that connects to it, take the shifter off there will be a roll pin hammer it out. slide the piece back and there is a spring and a little ball in there. once you get that part loose then the tail shaft will come loose. It is real simple i could talk you through it, but almost immposible to get to it still in the car.
RE: speedo issue
Here is a link to a tech article that has pics and everything..
https://mustangforums.com/m_1236295/tm.htm
lincolnshibuya
12-08-2015 04:37 PM
