solid tranny mount or poly mount for a wc t-5
RE: solid tranny mount or poly mount for a wc t-5
I'm running poly motor and tranny mounts. Running solid can will cause more vibrations and can also cause cracking issues. Something has to give between your motor/drivetrain....something has to flex or metal breaks. If you have solid motor mounts, go poly on the tranny mount or vice versa.
There is no reason to run anything other than a stock style mount. The solid mount is pulling the pin on your tailshafts case and the poly one makes for unwanted vibes. I have cars running far into the 8's with the stock mount.
jwog666
12-27-2021 08:09 PM
