a cam question
#22
RE: a cam question
the problem with the stock springs is that theyre usually worn out. this means you are missing alot on the top end. its just a good idea to put new springs in, whether they are stock or aftermarket
#23
RE: a cam question
ORIGINAL: 15austin
No way. stock springs are fine with b-cam.
Stock BRAND NEW exhaust springs become solid @ .510" lift and the intakes @.530". If you install a B-303 and don't upgrade the springs, you're @.030" from coil bind.......add a set of 1.7 rockers (.510" lift), and the exhaust springs are becoming solid @idle......over rev it.....and.......................you could hear......"thank you for doing business with us"---->(XX shop owner voice)...do it right, and you won't hear voices.......... My 2ยข.
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
