problem
Old Jan 6, 2007 | 08:20 PM
  #21
mattdel's Avatar
mattdel
Default RE: problem *updated*
uhh well she JUST pulled in, i called her to tell her to bring her camera, but it was too late. pretty standard setup though, chrome pipe off the tb down the the maf, and then just the filter on the maf, instead of another pipe to the filter.
Old Jan 6, 2007 | 08:23 PM
  #22
PRO50SC's Avatar
PRO50SC
The Rogue Mod
That shouldn't make it run like it is!! Hmmmmmmm.
Old Jan 6, 2007 | 08:24 PM
  #23
mattdel's Avatar
mattdel
the bucking was quite violent at some points. actually squealed the tires.
Old Jan 6, 2007 | 09:07 PM
  #24
gspfunk's Avatar
gspfunk
Unless the MAF is designed to have the filter attached to it, it will get inaccurate readings. The MAF needs to have somewhat smooth airflow going across it; hence why clocking a MAF works sometimes. But in your application, you've got the filter pulling air from all sides and then going directly into the stock MAF.
I may be incorrect, but I would bet that this is your problem. Try hooking the full kit up and see if the issue goes away. Also, disconnect your battery for a few minutes to reset the computer.
Old Jan 6, 2007 | 09:11 PM
  #25
mattdel's Avatar
mattdel
yah i'm thinking you may be right on that one... i'll have to open up my wheel well tomorrow. blah.
Old Jan 6, 2007 | 09:13 PM
  #26
gspfunk's Avatar
gspfunk
I didn't have to on mine. I ran the pipes and then just reached up from underneath to put the filter on.
Old Jan 7, 2007 | 03:30 AM
  #27
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: mattdel
ok so it was about 70 degree's here today, and i didn't have one problem with the bucking. i should have noted last night that it was raining cats and dogs while it was acting up. any thoughts?
have u checked the cap and rotor? and the plug wires mine acted up last winter when it rained with a smillar symptom did the parts been gone since then
Seanam
Oct 4, 2015 10:15 AM
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
