HELP: Idle Problem
Old Jan 7, 2007 | 11:58 AM
sdwrage's Avatar
sdwrage
Default HELP: Idle Problem
Hello all,
I have an 85 mustang gt with a 351 winsor engine ( high performance ), Carbuerated, 5 speed T5 transmittion me and my father are working on. We finally got it to start up after 4 months of converting it from a 302 with AOD and Fuel Injection. We even fixed a few vaccuum issues that were keeping the brakes from working properly. We are now facing the dilemma of the engine idling too high and was wondering what the problem could be. We have checked for any vaccuum issues but its hooked up to the same vaccuum T that the brake booster line is hooked to and that works perfect. Could it be that we have a racing carb on the vehicle? if not what else could it be? any help is appreciated.
Old Jan 7, 2007 | 01:14 PM
sdwrage's Avatar
sdwrage
Default RE: Really High IDLE??
can anyone at all help me?
Old Jan 7, 2007 | 01:32 PM
aode08's Avatar
aode08
turn your idle screw down until your happy
Old Jan 7, 2007 | 01:33 PM
AdderMk2's Avatar
AdderMk2
Banned
How big is the carb your running?
Old Jan 7, 2007 | 01:51 PM
sdwrage's Avatar
sdwrage
When you say turn the Idle screw down do you mean bring it out more? because my father has it all the way out. As for how big the carb is I will have to reply to this in a couple hours on that.
Old Jan 7, 2007 | 02:04 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
is this a real racing carb ie 4 corner idle circuitry? what is the timing set at this has to be set right before tuning carb
Old Jan 7, 2007 | 03:09 PM
sdwrage's Avatar
sdwrage
We havent set the timing yet because we were messing with the distributor to find an idle that is a bit lower (which of course throws off the timing). I will reply to wether its 4 corner idle circuitry in an hour.
Old Jan 7, 2007 | 04:32 PM
sdwrage's Avatar
sdwrage
It is a double pump carb with four corner idle system. We believe it is a holley 4150 Ultra HP series.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
