the same ole 3.73 ????
RE: the same ole 3.73 ????
ORIGINAL: AdderMk2
both... but which ones
ORIGINAL: PX429
I'm running both correction gears plus I have a GPS that tells me my exact speed.
I have 275/40/17's
I have 275/40/17's
Mathematically... it just doesnt work like that... you can directly connect the speed of the car to the RPMs of the engine based on the rolling diameter of a tire and the gears in the diff/trans.
3.08's is about 2250ish at 80mph, 3.55 is about 2500ish, 3.73 is 2650ish, and 4.10's SHOULD be 2800ish...
ORIGINAL: PX429
my tach is off?[sm=dontgetit.gif]
I doubt that.
ORIGINAL: AdderMk2
Thats weird... you should be closer to 2800rpm.... perhaps your tach is slightly off
I doubt that.
ORIGINAL: 5.0stanger
He is saying your tach is possibly reading lower than it should be...Mine reads higher(stock)
ORIGINAL: PX429
Edit: wait so when i shift am i really shifting at 6500 instead of 6200?
I doubt that.
ORIGINAL: AdderMk2
I doubt that.
lol...
ORIGINAL: AdderMk2
Are you possibly running an aftermarket tranny... perhaps a T5Z with a .63 overdrive?
ORIGINAL: PX429
idk... it just works out that way. at least on my end.
ORIGINAL: OnyxCobra
I have 3.55s and at 80mph i run about 2500rpm, so Adder's math is pretty accurate. I'd definitely expect higher than 2600rpm @ 80mph with 4.10 gears.
