aftermarket head questions
now this is not one of the "what kind should i get" question i have a more important question.
seeing as my 5.0l is NOT in a mustang, it is in a RX-7, the physical dementions of the heads are vary important to me.
i would like to know if the AFR 165's are the same size as stock heads. mostly i need to know if the AFR's will raise my valve covers any higher then stock. i am also planning on running 1.7 rockers, i thought this info would be important. any thoughs would be great and if some one could get a pic of a set of AFR 165's beside the stock E7 heads that would be even better.
thanks alot
thanks alot
RE: aftermarket head questions
ORIGINAL: highwayinthesky
thanks alot
thanks alot
this is true
so get urself some cobra valve covers and be done with it
ORIGINAL: OnyxCobra
What about Cobra valve covers? Mine dont look very tall at all, but i cant say I've seen a GT valve cover up close
first off why do you need 1.7 rockers?tons of cams based on a 1.6 and IF you need more lift then a simple rocker arm change is all that is need..also you can use 1.6's on a 1.7's base lift as well....they do now offer a thicker gasket that will keep the use of stock valve cover with 1.7's..but could possible interfere with intake, also a set of gt-40 heads would work well with a set of serve duty cut back valves which improve flow..off top my head around 5-8% even more with 5 angle valve job, but of coarse going to larger valve will unshroud the opening for better flow,mostly on the exhaust side....but if it was me I would opt for a set of canfield aluminum heads they flow well and as with any aluminum heads are up to 50 pounds lighter AND dissipate heat better
i was thinking of going with 1.7 rockers not for a huge cam but to help eliminate valve float and as a base for a sturdy top end. the aluminum heads are mostly to keep the wieght of the motor down (i am trying to keep the 50/50 wieght distribution of the mazda or atleast as close to 50/50 as possible) and to pick up a few extra ponies in the process. i have not heard of canfield heads before but hey, i am still a rotary guy at hart and this is my first piston motor. i think i will look into the cobra valve covers as i allready have a bunch of cobra parts and will try to find some measurements of the cobra covers. i would still like to get a bit of info on the gasket that fits 1.7 under the stock vavle covers, i didnt think that going to a 1.7 rocker would create such clearance issues. oh well, all i have fought in the swap so far has been clearance issues!!
