Turn Signal Problem
Turn Signal Problem
Well here's the deal. When I turn my ignition fully forward my turn signals don't work. But when I turn it back a little all my caution light come on then go out and the turn signals begin to work again. Has anyone else had this problem? And if so is it just the ignition that I need to change or something more difficult? Thanks for the help.
Luke
Luke
RE: Turn Signal Problem
I went through the same thing on my car it was a bad ignition switch (electrilcal part).I have also seen the screws come loose on them putting them out of adjustment.Look on the steering column under the dash the switch part is mounted to the column with a rod going into it.
musnicki
09-23-2015 07:11 AM
