Finally switch over to 3G
i went to the track and my alt was on its way out, i could barely get it above the "red" zone driving at full throttle. so i switch to the 3g and its great, brighter headlights, i can use my ac at stop lights now. it wasnt expensive either. but if you havent done it yet, i highy reccomend it. and it looks better too.
RE: Finally switch over to 3G
does the 3g have an internal regulator. so you can do away with the external regulator.....
reason being i need a better alternator setup being im about to put an eletrical fan on the stang... and also im going to hide my wiring in the fenders.if i can get rid of my external voltage regulator thats one less thing i have to hide i know alot of the aftermarket alternators from summit have internal regulators just wondered if the ones from the 94-95 stang had internal regulators....
You want to run a completely different power wire as the two ten gauage wires run up the harness a bit and splice together into one wire! A 3g can fry the stock power wire no problem.
This guy is an electrical engineer, he knows his stuff.
http://www.geocities.com/smithmonte/
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
