feul pump problems ??
Old Jan 21, 2007 | 08:38 PM
5.0_BLK94Stang's Avatar
5.0_BLK94Stang
Default feul pump problems ??
ok heres the problem my car is making this weird noise like a moaning noise I was told it was my feul pump and i was wondering if this is the reason my car isnt livly when i hit the gas peddle and if i hold down the gas a lil bit my car gurggles like its either getting to much or not enough gas and could this be the reason why my exhaust isnt sounding how it used to??
Old Jan 21, 2007 | 08:52 PM
5.0_BLK94Stang
Default RE: feul pump problems ??
please help me
Old Jan 21, 2007 | 09:18 PM
5.0_BLK94Stang
no one??
Old Jan 21, 2007 | 09:19 PM
SuperCharged93's Avatar
SuperCharged93
Buy or borrow a fuel pressure gauge. Install it on the return line, (relieve pressure first) turn on car, go to the gauge and see what the PSI is at. If it is stock it should be around 38 PSI. If it looks ok, go ahead and rev the engine and see if the PSI drops. Its should drop like about 6 or PSI on a rev. Anymore then you might have to change that pump.
Old Jan 21, 2007 | 09:37 PM
5.0_BLK94Stang
ok but does anything i explained sound like a fuel pump problem?
Old Jan 21, 2007 | 09:55 PM
nitrous_bob's Avatar
nitrous_bob
yeah kinda
when you turn on the key only...you should hear it hum for about 3-5 seconds
if your going lean or too phat it will not run strong
you really need to get a guage on it, see what it's doing.
could also be spark issues though, so you need to elimintae if it's fuel or spark, then start to narrow from there.
free way to check spark is to close the plug gap down to about .030" if it runs strong there, your sprak is weak for some reason, could be plugs, coil, dizzy , dizzy mod
but elimintae one of them, then go from there.
Old Jan 22, 2007 | 01:04 AM
Jon82387's Avatar
Jon82387
i just did my fuel pump in my 90 vert, my car was having problems starting would take like 1-4 cranks b4 it would start up and i noticed it was starting to run like crap once i got into 4k+ rpm range jerking and stuff. Put in a new 190lph bbk fuel pump from jegs also a note about the pumps if you get anything under a 190lph bbk pump it comes with much less things for the install, (the 190 came with a new strainer,new rubber hose,new harness, and new clips for the lines was pretty nice)MANNNNN it made a huge difference fuel pump was bad all the long [&:]
1TUFF302
Nov 5, 2015 04:02 PM
9550
Oct 26, 2015 05:01 PM
TfcCDR
Sep 14, 2015 12:08 PM
5.0 kevo
Sep 3, 2015 06:24 PM
