sn95 pulleys!
01-24-2007, 05:30 PM
sn95 pulleys!
does anyone know if sn95s came with underdrive pulleys? what is the stock alternator pulley size for a fox? thanks
01-24-2007, 06:12 PM
RE: sn95 pulleys!
anyone???
01-24-2007, 06:15 PM
RE: sn95 pulleys!
The stock '94/'95 alternator pulley is the same size as a Fox body 5.0 underdrive pulley. The stock Fox alternatorpulley is alot smaller.
Ive got one of each of the 3 pullies.
01-24-2007, 06:24 PM
RE: sn95 pulleys!
so i just did a 3g alt conversion from a sn95 and the lights dim at idle when the accesories and the stereo is on. could this be the problem?
01-24-2007, 07:39 PM
RE: sn95 pulleys!
bump
01-24-2007, 07:56 PM
RE: sn95 pulleys!
Quote:
ORIGINAL: elmustang5.0
Yes.
Use the stock pulley from your car's original alternator.
I had the same problem. When I put the stock pulley on I didnt have any problems with low voltage and dimming lights.
01-24-2007, 09:30 PM
RE: sn95 pulleys!
I just got a kit and it said to bump the idle up if you are having charging problems.
01-25-2007, 03:34 AM
RE: sn95 pulleys!
i'll have to buy a stock pulley cause it seems that the one on the stock alternator had an underdrive pulley. i measured it with the sn95 pulley and they are the same.
GimpyHSHS
19
12-19-2023 01:12 PM
spdeplayer2
10-24-2015 09:45 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
mikesr4565
Suspension
09-21-2015 10:26 AM
uedlose
09-10-2015 03:30 PM
1995 ,
95 ,
alt ,
alternator ,
body ,
diference ,
difference ,
fox ,
mustang ,
pulley ,
pulleys ,
sn95 ,
stock ,
underdrive ,
underdrives ,
upgrade
