Idea for more air flow...
say you have a CAI in the fenderwall.right, where the filter sits drop it down about 1 1/2 ft down near the ground sp colder air being blown up, also the filter would sit farther away from the engine bay(possible colder air), I drew a pict to show if you dont get what I mean. youll need a PVC or other type of pipe, clamp and elbow.would you gain from it?
[IMG]local://upfiles/4354/299666EFBF944E96970F5EA98AEF1578.jpg[/IMG]
RE: Idea for more air flow...
you mite actually loose horsepower from that juss because of all the bends ur making. the smoother the air intake is the more power ur gonna get. id stick with a fenderwll inake. but if u do make it and it does work let us no
I have a freind who owns a civic. He has the pipe running down parrallel with the bottom of the radiator. After he drives it for a while if you touch the pipe it's almost ice cold. He says the only draw back is when it rains and the roads get flooded he cant drive because it will choke out his engine. plus the chance of water surging up thru the pipe and ingesting in to your engine. The older 5.0 s had the air inlet running up from the bottom of the fender well. Kind of like a ram air system. Not much gain in HP with the stock air intake system though.
I've always thought that the ac unit blowin all that nice cold air inside the car could be channelled to the air intake system too.
ok so speaking of air intake, i've always heard that removing the silencer will give you small gains and better air intake but i uh.....dont know where it is can someone help me out please?
ORIGINAL: 5_liters
panic
09-10-2015 05:56 PM
