speed density engine to mass air?
RE: speed density engine to mass air?
ORIGINAL: ih8chevy
its a somewhat expensive and not too difficult switch. if i were i would just go carb or find a diff motor
alright thanks guys. so the engines are the same, thats sweet! so when converting to mass air you pretty much just need to change the fuel stuff? but thanks for the help!
the engines are identical as stated the only difference is the ECU, maf wiring, and vac line to the MAP....your swap is easy as can be...install the new motor EXACTLY the reverse of how you removed your old one and you should be running A1 in no time flat. Do not use the SD computer in your vehicle..keep your current ECU.
panic
08-25-2015 09:34 AM
