Anti-freeze leaking behind my water neck
RE: Anti-freeze leaking behind my water neck
if its stock its 10 but if someone has messed with it could be higher. if u get a fuel pressure regulator u can have a shop adjust it to what it needs to be. that or add a degree or 2 of timing it will lean it out a bit but u gotta remember with a higher timing means higher octane also if u ur timing becomes really high like mine use to be (mine was a 17) it became harder to start. i don't see that happeing in ur instance
jwog666
12-27-2021 08:09 PM
