overcharging battery help!!!
Old 02-05-2007, 11:42 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default overcharging battery help!!!
ok the other day i decided to get on it a little bit for the first time since i got the engine rebuilt and the craziest thing happened. as i'm getting through first gear about to throw into second i noticed my battery meter jumped through the roof above the redline and the amp light came on in my insturment panel. so i decided to test it again so i got on it again through first and it jumped through the roof again and goes down almost a second after i let off. whats the deal!?!?! was something not hooked up correctly. please help me i dont wanna blow up my car haahha!
FivePointOhh is offline
Old 02-05-2007, 12:51 PM
hosehound316
hosehound316's Avatar
Default RE: overcharging battery help!!!
Had the same thing happen in my 95 GT, I had bought a new alternator and the day after it was put on my battery gauge flipped out, they had to replace the alternator and its been fine since, good thing there is a lifetime warranty on my alt. Hope this helps you.
hosehound316 is offline
Old 02-05-2007, 12:53 PM
93 LX FiveO
93 LX FiveO's Avatar
overcharging
93 LX FiveO is offline
Old 02-05-2007, 12:56 PM
FivePointOhh
in limbo
how does an alternator going bad make my battery freak out like that? i would think it wouldnt want to charge at all if it was going bad.
FivePointOhh
in limbo
plus everything was fine before the rebuild.
Old 02-05-2007, 01:01 PM
mattdel
mattdel's Avatar
sounds like a bearing problem with the pulley. did you slam the alt down on the pulley during the rebuild?
mattdel is offline
Old 02-05-2007, 01:25 PM
FivePointOhh
in limbo
uh no...there is kind of a weird noise during idle. i think it might be the alt pully i had the same sound on my 98 mustang. it sounded like a grinding of rocks as it rotates along with a slight whine....does that sound about right? are you pretty sure its the alternator because i had a friend suggest maybe a voltage regulator is bad. what do you think?
BOB ROME
07-26-2023 01:54 PM
4cylinderplus2
10-09-2020 07:45 PM
logan409
09-26-2015 07:43 PM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
Art161
09-09-2015 10:33 AM
Quick Reply: overcharging battery help!!!
