Blew by Black Magic
Blew by Black Magic
I know its been asked a thousnad times but im going to switch my fan to electric before winter is over. I know i need a new alternator which im going to get. Ill probly end up with a 130a one that bolts right on. But how hard is it to actually disconnect the fan from the engine? The fan im gonna get is by black magic but im gonna look around for a cheaper one. Ive had the undrive pullies for a while so im gonna throw those on while im at it. Also will the 130a be enough or should i bump it up to 200a for s***s and giggles?
RE: Blew by Black Magic
Proform electric fan off jegs............ $125 has a thermostat does 2800cfm. i bought the flex-a-lite fan for $200 when that proform is the same ****in fan just $75 cheaper its very nice to have you can set it to keep running even after your car has been shut off until it cools to a certain temp. screw black magic its a good fan but not worth the money in my opinion
I have pulleys, a 130 amp Powermaster alt, a fluidyne rad and the Black Magic Xtreme, which I'm all happy with. It's not inexpensive though and work well together.
It's real straight forward disconnecting the existing fan/shroud and the instructions are easy to follow.
alright i know these questions and is this item good get annoying but i just need a quick opinion...would this work well in my 93 lx or should i look somewhere else. The junk yard dont have anything around here. http://cgi.ebay.com/ebaymotors/16-in...QQcmdZViewItem
Or where would you recommend getting the fan....id rather get a new one since im kinda **** about used things since i got taken on ebay but i want to afford new rims this summer.
whatever is the best im gonna get/
yes ebay fans work fine... i was gonna get some myself
my setup is gonna be 2 10" fans side by side except one higher than the other due to the inlet pipes and stuff on the radiator. also i'm gonna make them pushers to clean up room in the engine bay
when you get ebay fans most of the time you'll have to buy a relay from autozone tho.... like 10 bucks
get a junk year fan out of a late 80's early 90's tourus 3.8 pulls HUGE HUGE ammounts of air and is only 20 bucks and then a $50 kit that had the relay and thermastat stuff cant beat that
mungodrums
09-28-2015 10:54 PM
09-25-2015 09:06 AM
