Rear-END Vibratrion?!?!?
Old 10-22-2004, 04:56 PM
94BOOSTDCobra
94BOOSTDCobra's Avatar
Default Rear-END Vibratrion?!?!?
What the hell is going on?! I get a nasty vibration at about 65-70 mph. to the point that there is serious vibration.
Bent drivetrain?
Any help thanks
94BOOSTDCobra is offline
Old 10-22-2004, 04:59 PM
StangMang
StangMang's Avatar
Default RE: Rear-END Vibratrion?!?!?
At first when i saw this thread i was like [][][][]
but then i read it and was like
haha...but seriously...check your tire pressure, might be that...could be that one of your tires is loose....check lug nuts
StangMang is offline
Old 10-22-2004, 05:05 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
Tire or driveshaft out of balance, or bad u-joint are the most likely culprits
mdvaldosta is offline
Old 10-22-2004, 05:10 PM
90GTRagtop
90GTRagtop's Avatar
Along with pressure, check the tires for any unusual wear that could indicate belt seperation, and look at the wheels to see if you may have thrown a balancing weight. Also, did you recently have to lock up the rear tires in a stop? That could flat spot them and create a vibration. Also, although very rare, I have seen a driveshaft throw a wieght to cause a vibration.
Good Luck
90GTRagtop is offline
Old 10-27-2004, 12:03 PM
94BOOSTDCobra
thanks for the replies guys....turns out: Spider gears needed replacing and I have a set of Strange axles coming ...oh well at least the rear shall be pretty damn bullet proof now...or soon anyways..
Old 10-27-2004, 12:05 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
glad you got it fixed, too bad it was a rear-end problem
Old 10-27-2004, 12:21 PM
cammedlx
cammedlx's Avatar
yeah,but altleast you have a reason to make it bullet proof
cammedlx is offline
Rorin67
02-13-2006 06:37 PM
StupidTodd
11-08-2005 03:18 AM
redmustang83596
10-06-2005 03:39 PM
Dalthius
08-29-2005 02:05 AM
kfellers
04-04-2005 03:28 AM
Quick Reply: Rear-END Vibratrion?!?!?
