WR AOD issues Trans guys i need your help.
RE: WR AOD issues Trans guys i need your help.
since my last post i pulled the trans and went through it to check everything to make sure it was right and pulled the valve body and had a local shop rebuild it. today i put the lopo governor on and it still skips second and doesnt have OD. its more driveable now because at normal throttle it will shift out of first and goes right into 3rd. at WOT it doesnt wanna shift out of first unless i let off the gas then it goes right into 3rd and if i floor it again it tries to go back into 1st.. but if i drop the shifter all the way down to the low position it goes into 2nd and i can rev it out in 2nd bump the shift and it goes into 3rd but no OD :-(
any suggestions on why it wouldn't upshift to 2nd and why there is no OD are these related in anyway?
bryan616fl
01-25-2019 09:07 PM
KEM Motorworks
08-14-2015 10:13 PM
