how to install intake?
Old 02-26-2007, 01:43 PM
88canadianstang
88canadianstang's Avatar
Default RE: how to install intake?
You also need to unplug your injectors and the rest of the wiring harness and move it aside... Then your fuel rail needs to be removed from the top of your injectors and move it aside...Then unhook your coolant lines
Not required...... I did mine last summer and did not need to do this, make it as litttle work as possible it makes putting everything back together much easier.
88canadianstang is offline
Old 02-26-2007, 01:47 PM
samseed101
samseed101's Avatar
Here is a fairly detailed article explaining how to install an Explorer / GT40 intake on a Mustang.
samseed101 is offline
Old 02-26-2007, 01:48 PM
88BlueGT
88BlueGT's Avatar
http://www.allfordmustangs.com/techa...intakeswap.pdf
This might help a little bit also.
88BlueGT is offline
Old 02-26-2007, 01:57 PM
samseed101
samseed101's Avatar
ORIGINAL: 88canadianstang
Maybe I'm misreading your reply or something. But how did you change the lower intake if you did not remove the fuel rail or the fuel injectors?
edited to add: or did you meanyou just removed the rails and actually left the injetors attached to the rail and wire harness? Personally, that seems like too much extra effort really... trying to keep it out of the way and tryin gto keep the fuel from spilling out.
Granatelli Sales
01-20-2020 12:34 AM
cbird1177711
09-02-2015 04:12 PM
SYNY5TER
09-02-2015 01:35 AM
09-01-2015 08:16 PM
Quick Reply: how to install intake?
