cutting out
RE: cutting out
what MAF did you install.... i had this happen when i installed a c&l meter with my stock 19s on... it ended up being that i need to clock the MAF senser so that it got the right air reading. i would fool around with the meter and rotate it little by little and see if that helps... i know when i did mine i reset my puter everytime, i dont know if that was actually needed but i did it just to be safe.
RE: cutting out
That problem definately sounds MAF related. Are you sure the C&L MAF you bought has the rightcalibration tube for the 30# injectors cuz it sure sounds like it doesnt. The tubes are color coded so just remove the MAF and check out what color tube you have. Here's the link to C&L's Calibration tube chart page http://www.cnlperformance.com/calibration.html.
jwog666
12-27-2021 08:09 PM
