oil pressure gauge (oil sender)
Old 03-01-2007, 04:09 AM
Kielianaire
Kielianaire's Avatar
Default oil pressure gauge (oil sender)
I have a 94' cobra and was installing a volts and oil pressure gauge last night. Got everything hooked up besides the oil sender for the oul pressure. a new oil sender came with the gauge and is needed to replace the old one in the car in order for the gauge to work properly. The problem is that this new oil sender is much bigger, mostly wider, than the one in the car and will not fit becouse it is in such a tight spot![:@][:@][:@]
Kielianaire is offline
Old 03-01-2007, 04:37 AM
Evil_F
Evil_F's Avatar
Default RE: oil pressure gauge (oil sender)
Yeah', I had to get a fitting for my aftermarket gauge sender also.
Evil_F is offline
Old 03-01-2007, 05:47 AM
QUIKSVT
QUIKSVT's Avatar
get a T fitting and put the stock sender in the straight end of it, and then rotate the T to a position that will allow you enough space to get the new sender in too.. Much easier, and keeps you from having dead guages... I couldn't stand to have dead guages...
QUIKSVT is offline
Old 03-01-2007, 06:13 AM
kev2369
kev2369's Avatar
I can't think right now if 5.0's have it or not, but i know that a 4.6 has a fitting where the oil filter bolts to the block that you can put a sender in...
kev2369 is offline
jwog666
12-27-2021 08:09 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
wraith777
09-28-2015 10:49 AM
StalkerGT
09-25-2015 02:41 PM
Quick Reply: oil pressure gauge (oil sender)
