How can I go fast?
RE: How can I go fast?
yah 96gt what the hell are u thinking. 100hp with no heads or intake. what r u on crack? no offense but i want whatever parts ur bying if thats how much power ur getting
cam=20hp
pulleis=5hp
headers=15hp
h-pipe=15hp
cold air intake=5hp
heat spacer= almost nothing
#24 injectors= nothing without maf or bigger tb
gears=no hp, will make u quicker tho, and cost about $400 to install
that equals about 60hp gained if that.
cam=20hp
pulleis=5hp
headers=15hp
h-pipe=15hp
cold air intake=5hp
ORIGINAL: 87mustang347
cam=20hp
pulleis=5hp
headers=15hp
h-pipe=15hp
cold air intake=5hp
cam=20hp
pulleis=5hp
headers=15hp
h-pipe=15hp
cold air intake=5hp
Add an American thunder cat back exhaust from flowmaster exhaust 5hp
Maybe a fuel pressure reg. and bump the fule pressure up: 1-2hp
Then if you wanted more, you'd have to go into the motor..IE heads, cam...
Again all of this Depends on your budget.
ORIGINAL: mdvaldosta
As roundy likes to say, as well as that go-kart engine builder can't remember his name...
"Speed costs money, how fast ya wanna go?"
mabey that was a different post.
phenolic spacers (what you are referring to as heat spacers) help keep the upper intake manifold temperature down so that CAI you bought won't be a waste of money. Most air from a CAI gets heated back up to regular temps before it reaches the heads. So you will get a little bit of hp gain with the spacer. I've heard of up to 8whp with a warm air intake, but it was not a mustange engine.
09-16-2015 07:53 PM
