i have a 94 5.0 and was wondering what all i can do to it?
RE: i have a 94 5.0 and was wondering what all i can do to it?
Well with 1500.00 if it were me I'd prolly order a set of GT-40p's from tri-state cylinder heads. Then watch ebay and the local swap meets from a used intake for a couple a hundred. Then I'd get the Steeda #19 or one of Comp's new XFI / EFI Cams and a set of newFMS roller lifter. If you keep the cam selection mild it wont mess with the computer. Then find yourself a Calibrated MAF and some 24# injectors. Top it all off with a new or used CAI (you can usually find one cheap on ebay) Then bump your timing a couple of degrees to start andif you've bargin hunted enough the1500 should have just about covered it. However I do recommend getting this combo dyno tuned at the first opportunity.
That is basically what i just done, except i had to buy a lot of security stuff for ignition (coil, cap , wires, etc...) Using the Steeda 19 cam, though for his naturally aspirated car he might wanna run the 18, and the gt-40p's, bought that trick flow intake, rockers... I have right around 1500 in all of it and i bought throttle body and some other stuff... So it can be done
Id be concerned about the computer if he was too use the #18 cam. It has abit more overlap than I like too see in a cam unless your gettingit dynotuned right after.
ORIGINAL: Ninety5five0
^ nope, just have to get a MAF to match...Which a new larger MAF would be a nice lil upgrade anyways.
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
