WHAT TRANY??????
RE: WHAT TRANY??????
ok I think I found the tranny im goin to go with, its a kit o fround from a performance shop. the kit consist of aluminum 10.5 inch flywheel with bolts and dowls, aluminum drive shaft w/31 spline yoke(1330 u-joint), TKO 600 transmission part#TCET-4615 (.64 OD), Tremec zinc plated crossmember, Poly trans mount, McLeod 10.5"10 spline stage 3 clutch kit, H/D clutch fork, aluminum quadrent, firewall adjuster and cable, aluminum shift handle, Tremec 5 speed "Polished" ****, aluminum Tremec bellhousing w/pivot ball. Im almost positive im goin to go with a manual. So the kits kind of a lot its like 3000$ what do you guys think about the price and the kit?
TKO 600> G-Force T5
The TKO is a much stronger tranny than the G-Force, and you will hear that from everybody. With a 347, it will hold up a lot better than the G-Force if you plan to ever use a power adder in the future. Not to mention that they are about the same price.
C4 for auto and I went with the TKO 500, a Mcleod SFI bell housing and centerforce dual friction clutch. You obviously wouldn't miss with the TKO 600 either. In hindsight I should have gone with the 26 spline TKO 600, but I'm happy with my setup.
It all depends upon what you'll be doing with the car.
I would go with the Gforce, It would be plenty strong, and I do believe they are lighter than the rest. And I would buy the parts to build one up from a good used t-5. But if you dont already have a t-5 then this route may not be the best way to go for you price wise.
