cant find timing marks on balancer
i was trying to advance my timing today and i didnt quite understand the directions from t he sticky on here where it just said to make a mark on the balancer where you want your timing to be set. All i saw was a metal piece above it that said LINE. some help here would be appreciated. thanks
also whats a good moderate number to set my timing at if i am running 93?
There shjould be timing marks on the balancer from 0-30 i think, at leas that what mine is, and the metal peice would be the pointer/marker whatever you wanna call it, and like you said just make a nice visible line and what number timing you want and you should be able to see it better with the gun and what not. Anyway i would really suggest going over like 16-18 or so, every car is different tho, im running 16 and i have no detonation even with 87, so just bump it up a bit, take it around the block hit WOT and hear for pinging, and find a degrre that you like
ORIGINAL: deanzawistowski
is there any excessive wear in the engine when the timing us bumped from stock to 14 or 15? and what HP gains are normally expected with those numbers?
crawl under your car and clean off your balancer...engine off of course!!..then mark the little lines with chalk...helps with the timing light....you will see the marks when the #1 piston is +-30 degrees TDC.
Urambo Tauro
Aug 27, 2015 10:53 AM
Aug 12, 2015 05:39 PM
