Motor Bogging...Help...
Old 03-20-2007, 08:25 PM
AJRabbit
AJRabbit's Avatar
Default Motor Bogging...Help...
Today I installed a new 255lph fuel pump and high flow rails with fuel pressure regulator. The regulator is set to 40psi from the factory, or so they say. What is a good pressure to set it to in order to have the right amount of fuel running to the motor? I also did the edelbrock performer upper/lower intake, 76mm MAF, 70mm TB/EGR, 24lb injectors, and intake.
My car is bogging tremendously when im above 1/2 throttle and backfires a little here and there. What do i have to do here?
Thanks in advance for any help.
AJRabbit is offline
Old 03-20-2007, 08:31 PM
PONY GUY
PONY GUY's Avatar
Default RE: Motor Bogging...Help...
your getting too much fuel to me it sounds like get a fuel pressure guage and see what you press is at and start form there maybe its a bit high or you have a injector to is stickin open longer too
PONY GUY is offline
firehorse02
11-16-2015 11:28 AM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Drastang
09-30-2015 03:48 AM
logan409
09-26-2015 07:43 PM
Quick Reply: Motor Bogging...Help...
