Give me some ideas, please
Alright, I ported my intakes as some of you may know and I also converted to MAF. I also put on a BBK 70mm TB.
So anyways, I was having trouble with how my car was running...kind of poping and a little studder/bogging, checked TPS, timing, FP...all was good. Still the problem was there, changed out the 70mm back to stock, problem gone. I ran it a 100 miles or so with no issues and figure I would give the 70mm another try. I love how it runs with the 70mm, much faster, but still studders a little.
Example;
Say I take off from a dig hard, it pulls like it never has before, thur all gears with the 70mm, but when I let off the gas, and get on it easy, it will studder/bog a little untill it cleans out. Basically if I give it more gas itgets better, but just cruising it kind of like loads up.
Anyone that can enlighten me, it would be nice.
Example;
RE: Give me some ideas, please
ORIGINAL: 5.0stanger
Example;
Example;
ORIGINAL: frdmstng1986GT
sounds like you killed the low end airvelocity in youre intake manifold when you ported it. switching to the smaller TB kinda acted like a venturi in a carb.. it spead up the air going through it wich brought youre velocity back. just a guess though.
I am still open to other options...
Another thing, it very bad when it is cold taking off, then gets better.
I also noticed I can cruse just fine, no issue untill I mat it...it will rip just fine, jet off to just cruse again and it will bog/miss for a coupe seconds till it smooths out again, then all is fine. It is mainly an issue of when I hot rod to criuse, not the other way. I have ruled out over porting, just doesn't seem to be the case. I would guess that I would see it all the time.
Anyone got any other ideas????? I need HELP
AmericanMuscle4.6GT
11-10-2015 02:06 PM
ccdguy
09-19-2015 05:20 PM
jaiidutch
09-14-2015 10:29 AM
mungodrums
Suspension
09-07-2015 07:22 PM
